Author Topic: bleeding disc/drum brakes with prop/metering valves  (Read 6212 times)
Offline high perf mopar
« on: May 15, 2010 - 09:13:25 PM »
hello,,any input on bleeding a 1971 disc/drum brake setup all new with the factory replacement prop valve with metering block??the 71 shop manual says to hold open the metering valve but nothing about the prop valve,,,drawed the fluid thru the system with a mity vac vacuum bleeder hand pump and then tried to final bleed with brake pedal pump manual bleed..brakes wont work or pump fluid out when wheel cylinder valve open???????ive blead brakes on my last 4 cars with no problems but this time,,,theres a problem.it has power brakes with a recondiontioned power brake booster.its a bear to depress the brake pedal.primed the master until there was no air,,tightened the master lines after fluid came out...
the prop valve has a plug nut on the bottom where as the metering valve has a relief stud hanging down...will power bleeding be only recourse or what????alll factory replacement setup..prop valve/metering valve?????any thoughts????thanks tony.
« Last Edit: May 15, 2010 - 09:15:48 PM by 440 »
1971 barracuda
440-6 shaker
chrysler 3x2 competiton carbs mech,what chrysler should have done.
b-5 blue
"you got yourself some motor there boy!" 1973,,white lightning.MGM studios burt reynolds
Re: bleeding disc/drum brakes with prop/metering valves
« Reply #1 on: May 15, 2010 - 10:39:37 PM »
I just bleed the master & go the the furthest wheel & start bleeding out the air at each corner
Offline BIGSHCLUNK
« Reply #2 on: May 15, 2010 - 11:11:17 PM »
:grinyes:... aint no thang...
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #3 on: May 15, 2010 - 11:36:18 PM »
well thats not how its working today,,,thanks for the replys,,,,s.o.p as far as im concerned...the motors not running yet...so no vacuum,,,,r u guys saying this with the motor running????because u know what a bear it is to pump power brakes with the motor dead???the onle thing i can think of at this point is the 2 valves r not bleeding correctly,,,,by this method...
« Last Edit: May 15, 2010 - 11:49:40 PM by 440 »
1971 barracuda
440-6 shaker
b-5 blue
Offline BIGSHCLUNK
« Reply #4 on: May 15, 2010 - 11:50:40 PM »
Dont have to be running... sounds like your experieced in bleeding (I find lots of guys that "think" they are). Start in the right rear and just work it!. Maybe keep the valve out of the booster??
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #5 on: May 16, 2010 - 12:33:45 AM »
thanks,,,,but the real question is the 2 valves,,,,,,,,,1---prop,,,,,2----metering valve,,,,?2 valves on the same system?o.e.m.?i bleed fluid from all 4 corners,,,not a lot but some,,more than others and the rears wont work....its prob me but all things point to a locked system at all these vavles,,,,now how to release them,,,rumor has it they open at 35ft,lbs,,,but will close again,,,,what about opening the prop vavle at the plug???????im reaching...................
1971 barracuda
440-6 shaker
b-5 blue
Offline BIGSHCLUNK
« Reply #6 on: May 16, 2010 - 12:50:07 AM »
hmmm ... sure your masters ok?
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #7 on: May 16, 2010 - 12:51:24 AM »
now when u guys pumped your brakes for bleeding was it hard as heck to get pedal response with power brake booster to do this????//
1971 barracuda
440-6 shaker
b-5 blue
« Reply #8 on: May 16, 2010 - 12:52:47 AM »
yes,,,bench bleed brand new along with the booster....
1971 barracuda
440-6 shaker
b-5 blue
« Reply #9 on: May 16, 2010 - 12:55:51 AM »
it just doesnt seem right,,,but all these inline valves r new to me....a local mechanic says to start it at this point with engine vacuum and go from there but thats not how i have done things in the past...
1971 barracuda
440-6 shaker
b-5 blue
Offline ShelbyDogg
« Reply #10 on: May 16, 2010 - 12:29:44 PM »
Sounds like your system is plugged up.  Pumping power brakes without the engine running to bleed them, is just as easy as manual brakes.  I think that one of those valves are defective and plugged up.
« Reply #11 on: May 16, 2010 - 01:17:13 PM »
You have a restriction somewhere. Once you open up any of your brake bleeders, the pedal will go to the floor easily.
Offline 72cudamaan
« Reply #12 on: May 16, 2010 - 01:31:01 PM »
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #13 on: May 17, 2010 - 08:48:34 PM »
thanks for the response guys,,,after calling inline tube today to ask them whats wrong with there parts,,they told me its the low pressure brake warning switch!its designed to close off the rear lines when theres no fluid to operate the fronts. the fix is to open both front caliper bleeds and to run a hose from them to a jar.
and then apply the brake pedal to force the air bubbles out,,i had to close the driver side and do the passenger front by itself to bleed that side.without opening and closeing the bleeds at first..
it seems to work..after messing with it briefly after work today the front brakes now will apply,,,in the next few days i will do the same to the rears...apparently my mity-vac has seen better days.
1971 barracuda
440-6 shaker
b-5 blue
« Reply #14 on: May 22, 2010 - 09:42:25 PM »
yep,,the safety valve kep shutting off the flow to the rear,opened the fronts to allow air into them and used a branik g300 pressure bleeder to bleed the system..finally the rears flowed fluid.no more bubbles..bleed the front..no more fooling around with it until its running.target start up is memorial day weekend..we will see.tony
1971 barracuda
440-6 shaker
b-5 blue
