Author Topic: bleeding disc/drum brakes with prop/metering valves  (Read 6211 times)
Offline 72cudamaan
Re: bleeding disc/drum brakes with prop/metering valves
« Reply #15 on: May 22, 2010 - 09:50:21 PM »
 :2thumbs: Awesome.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline high perf mopar
« Reply #16 on: June 09, 2010 - 11:49:55 PM »
aftr bleeding with a power bleeder to the rears,,,flowing fluid,,,still no brakes...i am going to rebleed the master and install self bleeders in the rears and go from there,,,after int fire up nothing went right :swear:bent a pushrod,,,rebuilt power steering box poured oil,not leaked,all over the shop floor and the brakes,rear,did not work :swear:oh,,and my lottery ticket was a loser,,,,,,,nothing like tearing apart a brand new cuda........
1971 barracuda
440-6 shaker
chrysler 3x2 competiton carbs mech,what chrysler should have done.
b-5 blue
"you got yourself some motor there boy!" 1973,,white lightning.MGM studios burt reynolds
Offline 4 speed fish
« Reply #17 on: June 10, 2010 - 12:51:01 AM »
I had the same problem.It was my booster.It should not be that hard.Was your original booster rebuilt or was it an exchange.My booster was frozen solid.
« Reply #18 on: June 10, 2010 - 01:20:34 AM »
its an exchange rebuilt unit...bad maybe????????/who knows without changing everything..
1971 barracuda
440-6 shaker
b-5 blue
« Reply #19 on: June 12, 2010 - 10:21:22 AM »
Take the master cylinder off.If the pedal is still hard it is your booster.
« Reply #20 on: June 15, 2010 - 09:38:07 PM »
took the master off,,booster checked out fine,,replaced the master with another rebuilt unit,bleeding each line as it go's thru the prop valve and now it will bleed the rears! so far..will attempt to finish the full bleeding process tomorrow after work..
1971 barracuda
440-6 shaker
b-5 blue
