Author Topic: tie rods  (Read 834 times)
Offline barryv
tie rods
« on: May 17, 2010 - 09:44:49 AM »
hi,can someone tell me if it matters which is the inner  or outer tie rod  . i just want to make sure before i put parts back together,thanks :clueless:
Offline FJ5_440
  • Wisconsin
Re: tie rods
« Reply #1 on: May 17, 2010 - 10:23:13 AM »
I believe the factory had the left hand thread tie rod ends to the inside.  It shouldn't matter functionally, tne alignment guy will just have to turn the sleeve the other way to adjust.
** Shane **
Re: tie rods
« Reply #2 on: May 17, 2010 - 11:46:50 PM »
Left hand inner
Offline barryv
Re: tie rods
« Reply #3 on: May 18, 2010 - 09:21:10 AM »
thanks
Offline mjk289
Re: tie rods
« Reply #4 on: May 28, 2010 - 10:36:31 PM »
I'm rebuilding my front end now and mine are:
Passenger - Lefthand Outer, Righthand Inner
Driver - Lefthand Inner, Righthand Outer.
I believe they are factory because my car only has 76,000 miles, but I'm rebuilding the front end completely just for the hell of it.  Also, I'd like to mention how the replacement tie rods are a little different than the originals, so I'm not as confident that I'll get them threaded on in the right spot.
