Steering Column Connections - EZ Wiring Harness Re-wire
Author Topic: Steering Column Connections - EZ Wiring Harness Re-wire  (Read 6604 times)
Offline tomsa
    • My cars in swedish
Re: Steering Column Connections - EZ Wiring Harness Re-wire
« Reply #15 on: June 06, 2010 - 09:44:39 AM »
Yes, There is one flasher/relay for the direction signals, and another for the emergency flashers.
Great  :ylsuper:
Problems solved
It´s only one in my harnes and the pink wire is cut and connected to the red wire upp at the turn signal switch
