I had leaking valve cover seals with a set of cast aluminum valve covers. I bought new seals and have a set of stock stamped steel covers. When I switch them out, I didn't take into account the length of the bolt, which is longer for the cast covers, and broke off one bolt in the bottom left hole of the passenger head. I removed my A/C lines to get access. The bolt is stainless, and I drilled it with a cobalt bit. The threads were screwed up enough the new bolt wouldn't torque down. I tried a tap, but it wouldn't go in far enough into the blind hole. Not knowing how deep the hole is, I drilled into the water jacket!! My question is can I tap the hole in the cast head, and is there a helicoil with a blind hole to fill the leak? Or am I screwed, and have to get a new head?
