Author Topic: 440 exhaust manifolds  (Read 1291 times)
Offline 440 challenger
« on: May 19, 2010 - 03:57:47 PM »
I have a 74 440 motor home engine in my 71 Challenger. It has exhaust manifolds on it with casting #3751071 on the pass side and 3751068 on the drivers side. On the pass side there is less than a 5/32 drill bit clearance between it and the valve cover. A little more than 1/2 " on the drivers side. I have looked at a lot of 440's on different cars and they all have lots more clearance. I think the heads are # 231. Any suggestions? Thanks
Offline 72cudamaan
Re: 440 exhaust manifolds
« Reply #1 on: May 19, 2010 - 05:57:04 PM »
The manifold was probably warped at some point, so it was milled down. Aside from using double gaskets or having a spacer plate made,you will have to replace the manifold or live with it. :2cents:
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #2 on: May 20, 2010 - 10:53:02 AM »
I have seen them that close , not much you can do about moving them away , I am not sure the factory castings are all that consistant
« Reply #3 on: May 20, 2010 - 03:42:49 PM »
 I don't want to buy another manifold that is the same way. How hard is it to install TTI headers? Nicks has got a fairly good price on them.
« Last Edit: May 20, 2010 - 05:26:34 PM by 440 challenger »
Offline acudanut
« Reply #4 on: May 20, 2010 - 05:05:59 PM »
 Headers.. :22yikes: They create even more problems.
« Reply #5 on: May 20, 2010 - 05:24:21 PM »
Headers are no fun, but they do upgrade performance if that is a consideration. You would also have to modify your exhaust pipes. They would have to be shortened, and have collectors welded on to meet up with the headers.
