Author Topic: Arrggghhhh!! - Fuel Fitting- Update Fixed!  (Read 1164 times)
Offline CUDA JAS
  • vroooooom!
« on: May 19, 2010 - 08:49:45 PM »
Man...I am trying to finish up a new fuel system on my cuda, new pump, lines, filters and regulator, everything from the tank to the carb!  I have one fitting at the carb inlet that does not want to seal. :stomp:
I looked at the carb fitting and there is a little ridge all the way around the sealing surface on the inverted flare.  Could this be the problem?
I remade the line once just to make sure it was not the problem, and that helped a bit, I alos have tightend the crap out of the fitting, but it is still leaking a bit.
I think I may try a new carb fitting and see if that works! :dunno:
Any tips or suggestions.
This is my first fab project and I really want to use it....but at this point I may just scrap it and go with some premade lines.
 :1zhelp:
« Last Edit: May 30, 2010 - 10:13:19 PM by CUDA JAS »
74 'cuda 360/727
Just call me a gearhead!
Offline GoodysGotaCuda
Re: Arrggghhhh!! - Fuel Fitting
« Reply #1 on: May 20, 2010 - 12:31:35 AM »
Any cracks in the flares? I usually cut the tubing, file it flat, and use a countersink by hand to deburr the tubing before flaring it. Haven't had any leaks with mine. Everything needs to be as smooth as possible. You said you had a ridge, on the actual carb fitting?
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline CUDA JAS
  • vroooooom!
« Reply #2 on: May 20, 2010 - 07:09:38 AM »
No cracks that I can see.
Yes there is a ridge on the carb inlet fitting...I am guessing that is my issue.
Jason
74 'cuda 360/727
« Reply #3 on: May 20, 2010 - 10:55:31 AM »
most fuel lines are cheaply made & do not seal well , but you said you remade the flare so the ridge could eb the problem
Offline ntstlgl1970
  • T a c o c a t
« Reply #4 on: May 20, 2010 - 03:52:46 PM »
Since it wasn't mentioned in the previous posts, are you using a single or double flare? on the carb fittings (from what I see in the picture) it should be a double flare...
Offline CUDA JAS
  • vroooooom!
« Reply #5 on: May 20, 2010 - 04:16:07 PM »
Yes a double flare was used through out!
74 'cuda 360/727
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #6 on: May 20, 2010 - 05:57:48 PM »
Do the lines go on straight? If they are in a bind or at an odd angle sometimes they will leak. Just a thought.
                                               Matt B.
Matt
Offline CUDA JAS
  • vroooooom!
« Reply #7 on: May 29, 2010 - 11:20:06 PM »
Woooohoooo, finaly got it to seal.  Took a new inlet fitting, and a new line, but I finally got the fuel line to seal.
Tomorow I will fire it up and see if it stays dry!!!!
then..... :burnout: :bigsmile:
74 'cuda 360/727
Offline CUDA JAS
  • vroooooom!
Re: Arrggghhhh!! - Fuel Fitting- Update Fixed!
« Reply #8 on: May 30, 2010 - 10:15:25 PM »
Wooohoooo, took the car out for a spin today....everything is still dry!!!!!
Heres some pics of the finished product!
74 'cuda 360/727
Offline dodge freak 2
« Reply #9 on: May 31, 2010 - 06:55:53 PM »
That looks sweet.
Wish I had the tools and the willpower to red do the  trans lines.
I'm still  using the same fuel line from the pump to the rubber hose that I bent by hand 15 years ago, lol
