Author Topic: vintage air install  (Read 4889 times)
Offline leanburn
vintage air install
« on: May 19, 2010 - 10:22:53 PM »
i got my vintage air kit today, i'm looking for any tips that may help me out. the instructions make it look fairly simple [ of course ] but there is always something they miss or could have explained in further detail. any help would be appreiciated.
Offline Confederate Cuda
Re: vintage air install
« Reply #1 on: May 19, 2010 - 11:31:28 PM »
Make sure you connect a trinary switch. I don't think they include them in the kit.
Offline leanburn
« Reply #2 on: May 19, 2010 - 11:36:35 PM »
it shows a '' binary or trinary switch'' in the electrical schematics so i assume it comes with one. so what is this switch anyway?
Offline 67vertman
  • Member since 9-23-2005
« Reply #3 on: May 20, 2010 - 12:46:52 AM »
It's a safety switch for the electrical system.
« Reply #4 on: May 20, 2010 - 09:16:04 AM »
It is a safety switch that will shut down the compressor if the head pressure gets too high and thus would save your compressor if you were low on freon. I installed thier Gen IV kit and it did not come with a trinary switch.
Offline leanburn
« Reply #5 on: May 20, 2010 - 10:24:47 AM »
this is a gen IV as well, i will make sure i get one if not supplied. thanks guys.
Offline leanburn
« Reply #6 on: May 20, 2010 - 03:33:34 PM »
well that didn't take me long to give up. i started the install and when it came time to remove the defrost vents it looks like the entire dash has to come out. ive done that before and have to do it again this fall when i paint the car, i don't need the practice. looks like another summer of the car being parked on hot days. :stomp:
Offline Katfish
  • 70 Challenger
« Reply #7 on: May 20, 2010 - 05:49:22 PM »
Did your car come from the factory with AC, or is the add-on kit?
I have factory AC and want to eventually upgrade to the Sanden compressor.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #8 on: May 20, 2010 - 06:32:40 PM »
 i did one in a cuda we built last year and with the dash out. The top screws into the cowl so it would be allot easier to atleast drop the column and roll the dash back,
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline 70 383 SE
« Reply #9 on: May 20, 2010 - 06:42:31 PM »
I had chryco phone Vintage for me and ask some questions and one of the things he said you could not do is put their compressor on you factory system because it does not pump at  a high enough rate to do the job. Also if you want to keep your car looking original it can`t be done. Some lines have to be blocked at the fire wall and also some plates have to be put in the fire wall. The heater box is a bigger size and the glove-box has to be replaced with a smaller one. I believe their lines are also different too,so the originallity is definately gone when you are done. I wanted  to go with them because their compressor uses less horse-power and the controls are all new generation but with what has to be done and not looking stock, I have changed my mind and will re-do my factory A/C and put it back in. Hope my  :2cents: will help  :ylsuper:
70 383 SE Chally,2010 Chevy Silerado LTZ 4x4 crew-cab ,wifes car 2010 Honda Accord coupe......need to save gas somewhere.....hehehe
Offline Katfish
  • 70 Challenger
« Reply #10 on: May 20, 2010 - 07:35:26 PM »
That's good info, you might want to look at Classic Air in Tampa.  They claim to have a kit that will work with the factory underdash parts.
I'm still sitting on the sidelines, waiting for someone else to blaze the trail first.
http://www.classicautoair.com/MOPAR_OEM_Parts_Engine.html
« Last Edit: May 20, 2010 - 07:39:26 PM by Katfish »
Offline ajantics
    • Yeah......Im a drummer!
« Reply #11 on: May 20, 2010 - 07:54:27 PM »
Would anyone know if the vintage air kit will work with a MARCH pully system on a 340?
70 Barracuda
73 'Cuda
2003 Dodge Ram 3/4ton
2009 G37s
Offline Aussie Challenger
« Reply #12 on: May 21, 2010 - 08:34:59 AM »
I'm still waiting for someone to put up a diagram of the vac connections & controls under the dash. My Challenger was factory A/C but everything is disconnected inside the car, under the hood its all missing, I can work that out.
Any & all help appreciated, thanks.   :cheers:
Offline 70 383 SE
« Reply #13 on: May 21, 2010 - 04:25:49 PM »
Sorry Dave I can`t help you there,all of my A/C had been disconnected and removed when I got my car. I have all the parts but like you Iam going to need some pics and diagrams to put it all back properly. :clueless:  :dunno:
Offline the_engineers
« Reply #14 on: May 21, 2010 - 05:37:15 PM »
A smaller glove compartment?  :eek2:  'Cause there was so much space before  :screwy:
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
