Author Topic: how do Challenger fenders attach to the body...  (Read 775 times)
Offline challngd73
« on: May 22, 2010 - 04:16:13 PM »
Bolts I know, but right in front of the passenger door, where the fender attaches at the bottom of the car, mine is flapping in the breeze.  I see no spot where a bolt would mount it to the body. This is a new development.. The driver side, the metal looks as if it is welded on the underside to attach it.
OxfordMotorSports
Re: how do Challenger fenders attach to the body...
« Reply #1 on: May 22, 2010 - 04:32:35 PM »
There should be a threaded mount behind the lower fender on each side. Don't feel bad - I've cut many welded fender bottoms off of old cars. Some body shops just don't care and the customer rarely sees it.
Todd
« Last Edit: May 22, 2010 - 05:58:43 PM by OxfordMotorSports »
« Reply #2 on: May 28, 2010 - 09:14:07 AM »
On each side there should be...two studs, two U-nuts to hold the studs in the body  and two regular nuts with large body washers to hold the fender to the rocker.
