I have a speedo that hangs at 10mph when stopped.....and runs 10mph too high at all speeds...odometer is fine.
So I bought two gauge clusters at a swap meet awhile back aiming to get a good speedo.
One was $25, the other about $75 I think.
The $25 one I bought for the speedo first, as the rest was not in great shape.... and then I found the better $75 one with a clock in it and very clear plastic, needle paint is excellent etc.
Well, today I started tinkering. I hooked up the clock's connection to 12v and the case to ground, but no luck....I also tried spinning the setting gears and the hands dont move.... :stomp
Bummer. Oh well.
The speedo seems to spin OK. SO, aside from deciding what to do to replace the ammeter (clock wont interchange with any other hole as I had hoped), I guess all I can do is try it in the dash.
So then I started playing with the $25 cluster , complete with badly scratched plastic, broken ammeter and faded needles...which is now my test guineau pig.
I was able to get the speedo, which I thought was bad, freed up and it works when I spin it with a drill now....
The I looked at the odometer.
I know they arent meant to be changed....but my goal was to maybe match the "better" speedo's odometer to the current one in my car, even though I am sure THAT mileage is way wrong...or, reset it to zero....
Got it apart and now am stuck.,....how do you "clock" the odometer so it works right? It has to be possible.
It doesnt matter since my car is registered as an antique and they dont record the mileage anywhere on antiques. And in all likelihood I will just use the "better" speedo cluster as-is after all....even though its mileage shows different than what I have on my car's now.... which I am sure is ALSO wrong...LOL
It really isnt that important I guess ,but now I am very curious and frustrated after trying it and failing...its like a rubix cube...LOL
So....Anyone know the trick to reclock the odometer?
Or why the hands on my clock wont budge with the setting gizmo?
