Author Topic: Carb Chokes With Aftermarket Intakes  (Read 1523 times)
Offline Road_Runner
« on: May 23, 2010 - 04:20:26 PM »
My 73 318 2 bbl has a 'mechanical' thermostat that opens or shuts the choke based on the temp of the thermostat 'coil' attached to the top of the passenger side of the manifold.  The Ede Performer has provisions for this type of thermostat but most like the Ede LD4B, Performer RPM, etc. do not.  For those of you running these types of intakes what do you do for a choke mechanism?  Did you just install a cable operated manual choke cable like I did years ago on my Roadrunner or are there other common alternatives?  I notice all the Edelbrock carbs come in 'manual' or 'electric' choke versions.  What is required for the electric versions, add-on senders, etc.?  I'd really appreciate knowing what folks here are doing and how happy they are with their setup.  I know many people used to prefer the manual chokes just to be sure they were completely open when they were racing, etc.
Thanks, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline djwhog
Re: Carb Chokes With Aftermarket Intakes
« Reply #1 on: May 23, 2010 - 04:30:49 PM »
I woul go electric, just a ground and a hot when ignition is on.
You can then loosen or tighten the tension on the electric coil to come off as fast or slow as needed depending on your climate and engine combo etc.
You can also adjust the choke pull off too so once it starts it cracks the blade for what is needed in your combo. Set fast idle via steps etc...:)
Electric is the way to go buddy:)   :ylsuper:
Offline Road_Runner
« Reply #2 on: May 23, 2010 - 05:50:15 PM »
If that's all that is required to make the electric work I agree.  Sounds like it just measures the temp from the base of the carb which I guess isn't too different than my stock one that mounts to the top of the manifold and measures engine temp there.
Thanks, Jim
Offline the_engineers
« Reply #3 on: May 23, 2010 - 05:54:58 PM »
My Holley 750 has an electric choke on an Air-Gap intake.  As Hog said, just supply it with power and loosen the screws and turn to adjust.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline Road_Runner
« Reply #4 on: May 23, 2010 - 06:17:59 PM »
Where do you tap in to power, off the coil?  Just curious.
Thanks, Jim
Offline DoNotChallengeHer
  • Drive It Like You Stole It !
« Reply #5 on: May 23, 2010 - 06:20:36 PM »
Thanks, Jim
I used the accessory in the fuse box.  :2thumbs:
« Reply #6 on: May 23, 2010 - 06:23:42 PM »
Take power from the 12v feed at the ballast or at voltage reg , the 12v wires is generally dark blue in color
Offline Road_Runner
« Reply #7 on: May 23, 2010 - 07:08:28 PM »
Thanks for the info guys, I really appreciate the help!
Later, Jim
« Reply #8 on: May 23, 2010 - 07:16:37 PM »
or the Dark Blue wire for the alternator feed
Offline djwhog
« Reply #9 on: May 23, 2010 - 07:19:10 PM »
Yep I used the BK bl from the alt is close and easy.. good luck and you are welcome:)
