Author Topic: Starter question, Starter's in!! but......  (Read 1560 times)
Offline BIGSHCLUNK
« on: May 23, 2010 - 07:35:58 PM »
When your installing the Denso mini starter... HEMI.. stock ext man.. should I take the extension off or not?? I'm sure this has been posted but I dont remember...  :banghead:
« Last Edit: May 25, 2010 - 09:46:42 PM by BIGSHCLUNK »
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Re: Starter question, please remind me..
« Reply #1 on: May 23, 2010 - 07:39:22 PM »
yes it will interfere with the block
Offline BIGSHCLUNK
« Reply #2 on: May 23, 2010 - 10:12:37 PM »
Thought so... Thanks Neil!!  :thumbsup:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #3 on: May 24, 2010 - 01:14:08 AM »
 :2thumbs:
Offline BIGSHCLUNK
« Reply #4 on: May 24, 2010 - 11:07:26 PM »
I need some advise please,,,, put the starter up tonite. And I can't get the bolt to thead. The starter does not seem to sit quite all the way, its like its a few thousandths high!!  :clueless:  So I threaded the bolt through the trans facing front just to check. Look at the starter, you can see the mark from the bolt. Do I have to grind a liitle off the block, it so where exactly?? I dont think I'd need much but there's not lots of room either...   :feedback:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Re: Starter question, another complication.... ideas?
« Reply #5 on: May 24, 2010 - 11:22:38 PM »
I need more more clarity on where the issue is , it sounds like the starter is either hitting the block , or the bolt holes do not line up
Offline BIGSHCLUNK
« Reply #6 on: May 24, 2010 - 11:26:36 PM »
Neil, the top bolt hole is a hair off. I cant move it in (towards the block) even a hair closer. Of course I cant see anything when the starters in there either, I guessing its touching the block somewhere...
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline ntstlgl1970
  • T a c o c a t
« Reply #7 on: May 25, 2010 - 03:30:21 PM »
I had to grind/sand the opening in the block to get mine to fit, not a lot, just enough to get the casting "flash" area to be the same height as the surrounding area of the starter opening. Let me see if I have a picture....yeah - here you go. I don't think the starter pocket is a precision tolerance machining operation. It must be just casting differences, this 66 440 block needed clearancing, the 73 440 block in my car did not.
« Last Edit: May 25, 2010 - 03:37:12 PM by ntstlgl1970 »
Offline BIGSHCLUNK
« Reply #8 on: May 25, 2010 - 05:55:52 PM »
  :thumbsup: THANKS FOR POSTING THE PIC!
I've been thinking all day about what to do tonite. I even compared the new one to the old (ma) starter before I came in this morning. It seems just a little wider. I'm hoping all I need is the DREMEL, and not the angle grinder.  :dunno: All I seem to need os a few thousandths.... stay tuned!
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline BIGSHCLUNK
« Reply #9 on: May 25, 2010 - 09:43:07 PM »
A little grinding with a hi-tech tool tonite and the starter fits just fine!!  :2thumbs: Thanks again ntstlgl1970 for the insirational pic.  :grinyes:
I unwraped my battery cable ..................... not acceptable.....  :crying:
Another delay................  :banghead:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: Starter question, Starter's in!! but......
« Reply #10 on: May 26, 2010 - 08:52:23 AM »
new positive cable coming out to you. thanks
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline BIGSHCLUNK
« Reply #11 on: May 26, 2010 - 08:53:42 AM »
 :2thumbs:  :2thumbs:   :bigsmile:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
