Author Topic: Brake light help  (Read 4053 times)
Offline ShelbyDogg
Re: Brake light help
« Reply #15 on: June 29, 2010 - 10:13:45 AM »
Did you try connecting the 2 wires at the switch together, bypassing the switch?
Offline Cudaah
« Reply #16 on: June 29, 2010 - 04:07:57 PM »
Seen I had power to it but didnt even think of bypassing it.  I will try that this week.  Thanks
Offline Cudaah
« Reply #17 on: July 12, 2010 - 02:03:10 PM »
bypassed the switch and still nothing.
I am going to try another new turn signal switch and see what happens
Offline ShelbyDogg
« Reply #18 on: July 12, 2010 - 08:15:50 PM »
Did you use a test light on the brake switch?   Make a test light if you don't have one.
STEP 1.  When the switch is closed, you should have voltage on the white wire going into the turn signal switch.
          1a.(white comes from brake switch)    1b.(emergency flasher switch should be in the OFF position)
STEP 2.  If you have it there, then probe the DARK GREEN and BROWN wires coming out of the turn signal switch.
STEP 3. If you have it there, the wires go to the driver's kick panel plug behind the parking brake. Check the same 2 wires there. They go to the left and right brake lights from there. Check IN and OUT of that plug.
If you have step one but not step 2, unplug the turn signal connector and hook a jumper between WHITE and the BROWN wires and see if you get the right brake light on.
Let me know what you get.
