Author Topic: Coolant recovery tank question  (Read 865 times)
Offline chargerdemetrios
« on: May 26, 2010 - 08:55:57 AM »
I have a 1974 cuda that has a plastic coolant overflow recovery tank, that is mounted near the radiator.
There are 2 hoses attached to the cap at the top of the tank, one which is the overflow line to the plastic tank, and the other is the return line to the radiator (I would guess).
My question is, when I cut the two hoses that attach to the radiator, should both hoses extend to the BOTTOM OF THE TANK??  Or should the return hose go to the bottom of the tank, and the overflow line extend just to the inside of the plastic cap at the top of the tank?
Thanks for the help.
-Chargerdemetrios
Offline 73Chally
Re: Coolant recovery tank question
« Reply #1 on: May 26, 2010 - 09:12:20 AM »
The overflow line should just stick in the cap, I believe.
« Reply #2 on: May 26, 2010 - 11:13:19 AM »
Thanks for that.  Any idea about how long the return line should extend??
Offline 73Chally
« Reply #3 on: May 26, 2010 - 12:21:05 PM »
I ran mine to the bottom of the tank.  I can't say if that is correct or not, but I've driven it through the Texas summers and have never had a problem.
« Reply #4 on: May 26, 2010 - 03:35:09 PM »
 That was my guess, that the return line to the radiator should go down to the bottom of tank.  If I ran the return line to the top off the tank, how would the coolant return to the radiator.
Thanks.
