Author Topic: Melted Holley Site Plugs  (Read 5070 times)
Offline cwestra
« on: May 26, 2010 - 12:38:53 PM »
I recently purchased some inexpensive plastic site plugs for my Holleys so I could check and adjust the float level.  After around 10 minutes of running the engine and adjusting the floats I removed the plugs.  When I removed them I found they were melted and disintegrated at the end with particulate inside the bowl, a real mess.  Has anyone ever experienced anything like this before?
Corey - in Northern Indiana
Offline Supercuda
Re: Melted Holley Site Plugs
« Reply #1 on: May 26, 2010 - 02:05:53 PM »
Sounds like the wrong type of plastic was used. Apparently, inexpensive means "wrong" in this case. Bummer. Often, modern "gasoline" eats things like this, and THEN we find out that there is some chemical in there that was not, when the part was first produced.
« Reply #2 on: May 26, 2010 - 08:38:40 PM »
Yep had that happen to me too. I just went back to the brass screws.
Offline 72cudamaan
« Reply #3 on: May 26, 2010 - 10:36:54 PM »
Well, Holley says only use them for float adjustment but I woulda thought 10 minutes would be fine.
 Matter of fact, I believe I used them for a couple of weeks when I installed my street avenger carb.    ???
If I cant fix it, it's broke
Andy  (phukker whither)
Offline the_engineers
« Reply #4 on: May 26, 2010 - 11:33:34 PM »
Mine have been in for a year...no leaks or issues.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline ntstlgl1970
  • T a c o c a t
« Reply #5 on: May 27, 2010 - 02:37:48 AM »
That's weird, I've run the moroso clear plugs on every holley I've owned for years on end with no problems.
Offline FJ5_440
  • Wisconsin
« Reply #6 on: May 27, 2010 - 07:39:50 AM »
If you are running with them in, you might want to consider going back to brass.  Check it out--
 http://www.cuda-challenger.com/cc/index.php?topic=63915.0
** Shane **
Offline cwestra
« Reply #7 on: May 27, 2010 - 08:18:00 AM »
Thanks for the link, FJ5.  I guess I should have done a search on it first.  Sounds like I'm not the only one experiencing this problem.
Offline matt63
« Reply #8 on: May 30, 2010 - 10:41:00 PM »
I've had a couple break when installing or removing them so went back to brass.  The consequences of a plug breaking when the hood was closed scared me.
Matt in Edmonton
'68 Valiant
Offline cwestra
« Reply #9 on: May 31, 2010 - 10:31:56 AM »
I agree.  Not worth the risk at all.
Offline CUDA JAS
  • vroooooom!
« Reply #10 on: May 31, 2010 - 11:56:40 AM »
Hmmm I just put a set on the Moroso plugs in my carb.  Maybe I will pull them out...
The stories in the above link are kind scarry!!!
74 'cuda 360/727
Just call me a gearhead!
Offline cwestra
« Reply #11 on: May 31, 2010 - 12:57:40 PM »
Not sure about the Moroso plugs.  The ones I had trouble with were Holley brand.
Offline BIGSHCLUNK
« Reply #12 on: May 31, 2010 - 01:16:41 PM »
I put in plastic ones 3 years back.... I'll be out in the garage soon. I'm gona check mine......  :eek7:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline Aracer
« Reply #13 on: May 31, 2010 - 11:46:54 PM »
I'm using the Mr. Gasket ones and one is getting cloudy. Out they go. :2thumbs:
Offline cwestra
« Reply #14 on: June 04, 2010 - 02:15:45 PM »
I need to make a correction here.  The plugs I had trouble with were, in fact, Moroso (P/N: 65226) and not the Holley brand, as I stated (in error) above.  Jegs sells 3 different one piece plastic site plugs.  Cheapest are Moroso, then Mr. Gasket, then Holley.  All look similar.  I do have a set of the more expensive Holley's but am reluctant to even try them, as they look very similar to the Moroso's.
Just wanted to correct my error on the Holley brand.
« Last Edit: June 04, 2010 - 02:17:33 PM by cwestra »
