Author Topic: I need some idea's were to mount a MSD 6AL box!  (Read 4225 times)
« on: May 27, 2010 - 07:12:37 PM »
I'm looking for some idea's and pictures on mounting an MSD box? I'm thinking under the battery tray or on the firewall. With the firewall I'm a little apprehensive on drilling though the firewall and hitting the heater core or something?
Anyone have some pictures to post?  :picture:
Thanks Brad
Offline ajantics
    • Yeah......Im a drummer!
Re: I need some idea's were to mount a MSD 6AL box!
« Reply #1 on: May 27, 2010 - 07:41:36 PM »
I am also trying to find a good place to mount it. I heard that mounting it upside down moisture can get in it so I am thinking of mounting mine some where inside up in the dash, but I have no idea if it is possible  :clueless:
70 Barracuda
73 'Cuda
2003 Dodge Ram 3/4ton
2009 G37s
Offline mopar12372
    • mopartech
« Reply #2 on: May 27, 2010 - 07:43:45 PM »
ALL electronics hate heat . with that said , i would put it in the car under the dash if you have the room . like ignition coils mounted on the intake manifold (bad idea ) . the cooler the electronics the better they operate . YES the factory mounting position for the coil is a bad place for it . MYOP Bill
RESTO PICTURES
Offline 422STROKER
  • Member Since 6/3/06
« Reply #3 on: May 27, 2010 - 08:49:34 PM »
Brad, You remember seeing mine?
Tom
Tom
« Reply #4 on: May 27, 2010 - 08:54:20 PM »
Thanks Tom :2thumbs:, yep I do remember that were I got the idea. The only problem I have mounting it under the battery is I was going to mount the relays there too and the MSD box is bigger that what you have so it doesn't leave much if any room for the relays. I have a relay for my engine fan and am going to put relays on the headlights too.
Offline 422STROKER
« Reply #5 on: May 27, 2010 - 08:59:52 PM »
I actually have an MSD-6AL under there now and these are/were there too!
I made as simple bracket for 3 relays and made a plate to bolt the fuse block/distribution stuff under the battery tray.  never had a problem with moisture and I drive in the rain as you remember!LOL
Tom
Tom
« Reply #6 on: May 27, 2010 - 09:04:48 PM »
Looks VERY tidy! :2thumbs:
Offline tommyg29
« Reply #7 on: May 27, 2010 - 10:41:09 PM »
Got mine under there too.
Just need to make sure you keep the area neutralized from battery acid!!
Offline mopar12372
    • mopartech
« Reply #8 on: June 03, 2010 - 08:37:03 PM »
that would be sweet if you installed a optima/excide jell cell so you dont have to worry about acid.
RESTO PICTURES
Offline elevenssc
« Reply #9 on: June 03, 2010 - 10:44:44 PM »
I mounted mine inside the passenger compartment on the tranny tunnel.
I do not have a console so there was plenty of room.  My Cuda is a tripple black convertible and I wanted to keep heat from becoming a factor.  The red box looks kinda cool on the black carpet.  I can take photos this weekend...
« Reply #10 on: June 03, 2010 - 10:50:56 PM »
Thanks all !!!  I mounted mine under the battery tray. It's tight in there with the relay's for the headlights and the Mopar MSD box but it all fits! I need a new battery tray, but I'll pick one up at Carlisle next month!
Offline barracuda7199
  • needs a resto but having to much fun right now
« Reply #11 on: June 03, 2010 - 10:55:23 PM »
72challorange where did you get the fuse block? also the big fuses? that is very neat work very professional
Brandon
71 Barracuda 440 727
(O O {]{]{]|[}[}[} O O)
Offline 422STROKER
« Reply #12 on: June 04, 2010 - 12:00:19 AM »
Thanks, I pre-wired most of it out of the car to get the fit right.
Autozone for the fuseblock and Walmart for the big ones. :chatting:
Tom :2thumbs:
Tom
