Author Topic: switched to electronic distributor, need help with wiring it?  (Read 1160 times)
I had a points distributor and switched to electronic, need some help wiring it up. I have a bundle of wires for coil, alternator, and distributor and don't know what goes were? I'm also wiring in an MSD 6AL box as well.
Thanks Brad
Re: switched to electronic distributor, need help with wiring it?
« Reply #1 on: May 28, 2010 - 10:22:21 AM »
MSD requires power from both the blue 12v run wire & the brown start wire to the small red trigger wire for the MSD
 the MSD has wiring for the coil & dist , the factory wires for the Dist & coil are not used , neither is the ballast resister
« Reply #2 on: June 02, 2010 - 07:27:22 AM »
Thanks Neil! :2thumbs:  I haven't looked yet ( I just mounted the box) were are the blue 12v and brown wires? What were they attched to stock? So the both get attached to the small red wire?
« Reply #3 on: June 02, 2010 - 12:12:40 PM »
they are at both ends of the single ballast resister
