Author Topic: Bleeding my Hyd clutch  (Read 639 times)
Offline GreenFish
« on: May 28, 2010 - 12:47:24 PM »
so I've got myself a new Ram Hyd release bearing. A different brand than the last one I had from keisler.  I have the remote bleed kit as well.
So do i just put fluid in it and slowly pump the clutch and bleed it like a brake line? Or is there a special trick I have to do for this?
thanks
Offline 72cudamaan
Re: Bleeding my Hyd clutch
« Reply #1 on: May 28, 2010 - 09:51:45 PM »
Yep, bleeds just like a brake line.
If I cant fix it, it's broke
Andy  (phukker whither)
