Author Topic: How to test 71 Cuda Rally Tach  (Read 1684 times)
Offline DocMel
« on: May 28, 2010 - 01:31:13 PM »
I cant seem to get my original 71 Cuda Rally Tach to work  I have acces to thge leads directly of the tach   Any way I can I can bench test it?
Footnote;   I cant tell you if it had points ignition origally or not   It did have a MSD nonvacum distributor when I got it
   I put in an aftermarket vacum electronic points distro and am running a stock type coil.   The tach has never worked since I got the car
How can I bench test the tach?  I treid connecting the tach to the pos on the coil, but no joy...
Any suggestions?
ir
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
Re: How to test 71 Cuda Rally Tach
« Reply #1 on: May 28, 2010 - 05:34:05 PM »
the tac  green with yellow tracer wire connects to the neg. side of the coil,,dont know if u can bench test
« Last Edit: May 28, 2010 - 05:36:26 PM by 72rtchallenger »
72rtchallenger
what happens in the garage
stays in the garage
« Reply #2 on: May 28, 2010 - 07:11:31 PM »
I'm not an electrician, but from what I recall you would need an ocilloscope to re-create the sine wave that the coil generates. That should send that correct pulses that the tachometer is looking for.
Offline ShelbyDogg
« Reply #3 on: May 30, 2010 - 06:05:30 PM »
Just hook 2 wires to it. The female spade goes to 12v, the post goes to a coils negative. Surely you can alligator clip it to a running car somewhere.
