Author Topic: Champion RJ12YC Spark Plugs for 440  (Read 7667 times)
Offline 7Dcuda
« on: May 31, 2010 - 08:11:57 PM »
After doing a search for the best suggested spark plug for a 440 I derived at the answer of Champion RJ12YC.   So I  just bought them to discover that the tip/threaded portion of the RJ12YC's  are much longer than the Bosch plug that I removed.  Do you have to have a certain setup to run the RJ12YC's?  Since the plug that I removed is shorter than the  RJ12YC I'm concerned that the  RJ12YC  is too long.  Can someone clarify this...any info. would be appreciated.
Offline 72cudamaan
Re: Champion RJ12YC Spark Plugs for 440
« Reply #1 on: May 31, 2010 - 08:16:25 PM »
Stock heads or aluminum?            Stock pistons or domes?
If I cant fix it, it's broke
Andy  (phukker whither)
Offline 71chally416
    • The Streetwalker
« Reply #2 on: May 31, 2010 - 08:22:11 PM »
If the plug is too long it'll just carbon up the threads sticking into the combustion chamber and make it difficult to remove.
Offline 7Dcuda
« Reply #3 on: May 31, 2010 - 08:23:12 PM »
Stock Heads, flat top pistons
Offline 72cudamaan
« Reply #4 on: May 31, 2010 - 10:15:53 PM »
Well , an rj12yc plug has awfully short threads. I am surprised that  the Bosch plug has shorter threads. Are u sure on the part #  of the plug u have right now ?
« Last Edit: June 01, 2010 - 08:24:53 AM by 72cudamaan »
« Reply #5 on: June 01, 2010 - 02:48:29 AM »
RJ12YC is the correct plug for your engine
Offline 7Dcuda
« Reply #6 on: June 01, 2010 - 08:23:35 AM »
OK thanks...not sure how much room there is between the piston and the plug when the piston is at TDC so when I saw how much longer the RJ12YC was compared to the plug I removed it worried me.
Offline ireland383
« Reply #7 on: June 01, 2010 - 07:58:43 PM »
     :iagree:  That is the correct plug.
1971 Plymouth Barracuda
