Author Topic: A-833 Manual Trans/ Truck or Car?  (Read 1515 times)
Offline 73 epic Challenger
« on: June 01, 2010 - 03:37:21 PM »
Is there a difference between a Mid 80's Truck A-833 Transmission and a 76 Volare A-833 Transmission? I believe the ouput is different but is there a difference in the gearing or bell housing? I converting my auto in my 73 challenger and need a donar. Thanks for the help JD
73 Challenger w/340
72 K5 Blazer Sb 350 auto
80 CJ5
80 CJ5
92 YJ/ Multiport FI AMC401, turbo 400, lowmax 300, Dana 44's
76 Waggy
Offline Changin Gears
Re: A-833 Manual Trans/ Truck or Car?
« Reply #1 on: June 01, 2010 - 08:53:03 PM »
The Volare a833 is has the a-body tailhousing, while the truck has the b/e body housing.
Offline 73Chally
« Reply #2 on: June 01, 2010 - 08:56:26 PM »
I believe the truck transmission should work for you, but the gears have a wider ratio between them, meaning that you will get a larger RPM drop when shifting to the next gear.  If you are running a big block the torque should help hide this, but with a small block it will be more noticeable.
« Reply #3 on: June 02, 2010 - 12:11:05 PM »
the truck one is geared slightly differently witha taller OD & is the bolt in for the B & E body cars the Volare has a totally different / shorter tailshaft & mounts
« Reply #4 on: June 02, 2010 - 07:27:55 PM »
So I Scored today on the 833, Ive been walking the junkyards and finally-Bell housing, trans, shifter and linkage $91.00 Who would have guessed half price Wednesday! Now all I need is a set of pedals! :bigsmile:
« Last Edit: June 03, 2010 - 12:00:55 AM by 73 epic Challenger »
73 Challenger w/340
80 CJ5
80 CJ5
76 Waggy
« Reply #5 on: June 03, 2010 - 12:18:46 PM »
good score  :2thumbs:
Offline Aussie Challenger
« Reply #6 on: June 04, 2010 - 06:38:38 AM »
Check Brewers as it might pay you to use new pedals, they are not that expensive.   :2thumbs:
 :iagree:  Great price on the box, did you get the yoke as well as if you have the 904 trans it is smaller than the 727 or manual box.   :cheers:
