Author Topic: Intake swap question  (Read 705 times)
Offline smallblock
« on: June 04, 2010 - 03:40:55 AM »
I recently found an intake with two four barrel AFB carbs that the guy says will only fit 0n 64-65 273 engines. Wouldnt this fit on later small blocks? I have a 74 318 I was wanting to put it on. I am runnung the 302 casting closed chamber heads but still think it would fit. Any help would be great. Thanks.
Offline Aussie Challenger
Re: Intake swap question
« Reply #1 on: June 04, 2010 - 06:13:54 AM »
Check the angle of the hold down bolts, the early 273 were different to later heads & 318, 340 & 360 heads. Also the 302 heads are the same as the 318, 340 & 360's.   :cheers:
« Reply #2 on: June 05, 2010 - 07:13:51 PM »
the early 273 had a different angle on the intake bolts so it will not fit anything after 65 LA engines
