Author Topic: Fluid Replacement Question  (Read 1869 times)
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« on: June 04, 2010 - 04:47:35 AM »
What's the best type of transmission fluid to put into a stock 727 trans?
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Re: Fluid Replacement Question
« Reply #1 on: June 04, 2010 - 05:26:25 AM »
Hey Larry....What you doing up in the middle of the night?
Wade
Offline tactransman
« Reply #2 on: June 04, 2010 - 01:00:17 PM »
Dexron
Terry-tactransman
Union, Mo.
Offline hooD
  • detroit iron
« Reply #3 on: June 05, 2010 - 04:25:38 AM »
Wade
My shift at work was changed.  I start at 6:30pm until 3am.  I get home around 3:30-4am.
-Larry
1973 'CUDA 340
original owner
37,117 miles
Offline hooD
  • detroit iron
« Reply #4 on: June 05, 2010 - 04:29:45 AM »
Dexron
Believe it or not, my fluid is the factory juice.  There is 36,000 miles on it.  It's still pink, but I really think it needs to be freshened up.  I don't have any problems at all, so maybe I should leave it be.  Any thoughts?
-Larry
1973 'CUDA 340
original owner
37,117 miles
Offline tactransman
« Reply #5 on: June 05, 2010 - 02:30:39 PM »
I would change it,just to get a new filter in there.
Terry-tactransman
Union, Mo.
Offline boxfox
« Reply #6 on: June 06, 2010 - 12:08:08 PM »
I have heard a lot of people talk about Type-F in 727's and I just had to replace my transmission and the shop that did the transmission work recommended Type-F and so I am filling it with Type-F
Offline heminut
« Reply #7 on: June 07, 2010 - 02:35:37 AM »
I've been running Type F in my 727 for 9 years with no problems.
1970 5.7 Hemi Cuda
« Reply #8 on: June 07, 2010 - 09:25:52 AM »
The specified type is Dextron III, I think the current version is VI ...
from http://www.mobil.com/USA-English/MotorOil/Other_Products/Mobil_Type_F_ATF.aspx
Mobil ATF Type F is not recommended for automatic transmissions in Ford, General Motors, Chrysler, American Motors, or any other cars requiring a Dexron-II, Dexron-IIE, Dexron-III or Mercon-approved fluid, or for those Ford products requiring an M2C138CJ (Type CJ) fluid or an M2C166H (Type H) fluid. For the above applications, Mobil ATF D/M (Dexron/Mercon) or Mobil Multi-Vehicle ATF are recommended.
Offline tactransman
« Reply #9 on: June 07, 2010 - 09:33:34 AM »
Dexron VI is   :money: :money: :money:  :faint:
Terry-tactransman
Union, Mo.
« Reply #10 on: June 07, 2010 - 10:12:38 AM »
  I bought a gallon of Dextron/Mercron from Tractor Supply, if I remember correctly for $12.00
Bet hey, if it's gonna be another 32 years spring for the good stuff.   :poopoke:
  Larry, Last time I had my tranny pan off I also drained the converter, about 1/2 the fluid is in the converter I suppose....Between that & a leak I'm up to about 2 1/2 gallons of fluid.  Might wait to see how pink the fluid is when you get it in the drain pan, you may be surprised.
 Wade
« Last Edit: June 07, 2010 - 10:25:59 AM by Bullitt- »
Offline tactransman
« Reply #11 on: June 07, 2010 - 10:53:03 AM »
Dex 6 is about $27-$30 a gallon.
Terry-tactransman
Union, Mo.
Offline hooD
  • detroit iron
« Reply #12 on: June 10, 2010 - 05:08:05 AM »
Filter recommendation?
-Larry
1973 'CUDA 340
original owner
37,117 miles
Offline hooD
  • detroit iron
« Reply #13 on: June 10, 2010 - 05:12:44 AM »
 Wade
If I just drain what's in the pan and leave the torque converter alone, how many quarts would that be about?   I'm afraid of shocking the trans with all new fluid.  Some people say that it will do more harm than good when it is all changed at once, so they claim you should do it in small increments.  Is this just a myth?
« Last Edit: June 10, 2010 - 05:16:53 AM by hooD »
-Larry
1973 'CUDA 340
original owner
37,117 miles
Offline tactransman
« Reply #14 on: June 10, 2010 - 06:56:21 AM »
You will need about 4 qts with a stock pan.
Terry-tactransman
Union, Mo.
