Author Topic: question about Accel "header" plugs  (Read 556 times)
Offline shadango
« on: June 04, 2010 - 05:12:59 PM »
My engine has been running a set of Accel header plugs.....no pings, runs good....so I was going to just replace them with the same thing....but at $30 a set, I am wondering if they are worth it.....They seem to be sold for the purpose of working "better" with headers.....But I have dougs headers, which seem to be pretty easy as far as plugs....
Are these Accel plugs worth it?  I just seafoamed and wanted to swap out the plugs just to be safe and fresh.
Offline mopar12372
    • mopartech
Re: question about Accel "header" plugs
« Reply #1 on: June 04, 2010 - 06:37:47 PM »
a set of autolite platnum  will work just fine , they come with a 3 year replacement warrenty too.
RESTO PICTURES
Offline 72cudamaan
« Reply #2 on: June 04, 2010 - 09:57:02 PM »
If you don't need the clearance that is gained by using a shorter porcelain then by all means use a regular plug. Might as well save the money for something else. Also, I do believe that Accel plugs are made by Champion anyway.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline Jim
« Reply #3 on: June 04, 2010 - 11:39:20 PM »
I've had good results with the Accel plugs, but the clearance gains are minimal.
-Jim
"Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. "
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #4 on: June 04, 2010 - 11:45:48 PM »
I didn't have good luck with the accels.  Used several sets.
I couldn't get the little nipples to stay screwed on, even when I crushed them on the threads.
auto lite platinums
Offline Changin Gears
« Reply #5 on: June 05, 2010 - 07:24:29 AM »
I've never used a full set of header clearance plugs, just the 1 or 2 cylinders that needed the clearance.
Offline shadango
« Reply #6 on: June 05, 2010 - 06:10:30 PM »
Thanks guys
Turns out I dont have the "header" plugs ...just the plain #115 U-groove plugs.
I found a set locally.   :2thumbs:
My old plugs were gapped funny...some were at
.030 and most were at like .040 plus.
Standard champs are supposed to be around .035 as I recall...and these are u-grooved....so I kept the .030 as they were shipped....figuring the grooved part is probably closer to .035.
Offline mopar12372
    • mopartech
« Reply #7 on: June 06, 2010 - 10:34:24 PM »
(fyi)spark plug gap depends on the ignition set up you are running.
RESTO PICTURES
