Author Topic: 440 flat slugs and rods in 400  (Read 3142 times)
Offline mytmopar
  • 69 gtx 440 vert-71 chally 340 blown-70 R/T coronet
« on: May 20, 2002 - 08:54:53 PM »
anybody out there know if a set of standard flat top pistons out of a 440hp will fit in a 400? any help would be appreciated.  mike in tn ???
« Last Edit: December 31, 1969 - 07:00:00 PM by 1023595200 »
get in, sit down, buckle up, and hold on! see you later, BYE!!
Re: 440 flat slugs and rods in 400
« Reply #1 on: May 21, 2002 - 02:58:05 AM »
No they won`t fit they 440 is 4.32 bore & the 400 is 4.35 bore so they are .030  to small , the other problem is the height ,the 440 is approx 1/2" taller deck than the 400 so the piston will stop about 1/2 into the head unless you use a much shorter rod
Offline mytmopar
« Reply #2 on: May 22, 2002 - 07:40:12 AM »
thanks for the reply. been into hotrods since kid but can now really afford to do more than 4 barrel and headers. :P
« Reply #3 on: May 23, 2002 - 02:57:39 AM »
You are welcome ;)
