Author Topic: Hemi 4 Speed?  (Read 845 times)
Offline Mopar_Mudder
  • I'm a llama!
Hemi 4 Speed?
« on: June 05, 2010 - 09:34:03 AM »
Would the 4 speed out of a 69 Hemi Road Runner be they same type that would go into a 71 Cuda?
1971 Hemi Cuda
2005 SRT-10 Regular Cab Flame Red.   12.771 @ 109.67 <-----Time Slip --Video
Mopar: Headers, Exhaust, Ram Air, ECM
2008 3500 Mega Cab Dually, Resistal Edition
Offline Changin Gears
Re: Hemi 4 Speed?
« Reply #1 on: June 05, 2010 - 10:31:57 AM »
No, the tailshaft is different.  You could install the tailshaft from a non-hemi e-body or truck trans though (The rest would work).
Re: Hemi 4 Speed?
« Reply #2 on: June 05, 2010 - 11:32:10 AM »
Good article on the differences. Read 2nd paragraph.
http://www.slantsix.org/articles/4-speeds/ODA833fourspeed1.htm
  • I'm a llama!
Re: Hemi 4 Speed?
« Reply #3 on: June 17, 2010 - 05:49:51 PM »
So am I reading correct that the only difference from a Hemi to a regular 833 is the input shaft? Is the shaft itself the same diameter and just has less splines.
I guess what I am asking is their any reason that a 23 spline 833 would not hold up behind a hemi? It isn't an original hemi car so I am not really set on having to have a Hemi 4 Speed if a standard one will do and be as stong for cheaper. Can you get the correct clutch to hold up with the 23 spline?
1971 Hemi Cuda
Re: Hemi 4 Speed?
« Reply #4 on: June 17, 2010 - 06:43:17 PM »
The angle the gear teeth are cut at is less in the Hemi box, this is what makes it stronger (and more gear whine).
Many a 23 spline has lived behind a 440 with slicks for a long time, my hemi and 440  have 23 splines now.
Re: Hemi 4 Speed?
« Reply #5 on: June 17, 2010 - 11:03:11 PM »
Hemi 4 speeds have a bigger OD dia. support bearing in the tailshaft than the 23 spline.
