Author Topic: Steering column wont let go of the key...  (Read 1359 times)
Offline elevenssc
« on: June 05, 2010 - 11:16:00 PM »
Steering column key switch wont allow me to "push in and rotate CCW" to allow me to pull the key out.  Key is installed teeth up, so this is not the problem...any ideas?
Offline Moparal
Re: Steering column wont let go of the key...
« Reply #1 on: June 06, 2010 - 12:03:22 AM »
70 steering column?  Right in front of your key is the last column tube. The linkage on the column to the trans linkage usually pushs the part up. Turn that part of the column closest to the dash by hand counter clock wise, then remove the key. This may be it
« Reply #2 on: June 06, 2010 - 01:11:48 AM »
also check the linkage lever on the steering column from the engine bay side. If the linkage is missing or not adjusted right it won't let you take out the key. I have to move that lever all the way down to remove my key.
Offline inot2old
« Reply #3 on: June 06, 2010 - 03:21:58 PM »
My linkage got knocked off when I hit a bump too hard & now my car won't go in park, so the key won't come out.
'71 Cuda
'70 Charger project
'05 Crossfire Roadster
Alaskan_TA
« Reply #4 on: June 06, 2010 - 07:53:12 PM »
For anyone that needs info on the 1970 interlock linkage there are diagrams here, just find your application;
http://www.hamtramck-historical.com/ServiceHighlights/1970PassengerCarHighlights14.shtml
More info here;
http://www.hamtramck-historical.com/ServiceHighlights/1970PassengerCarHighlights11.shtml
Offline elevenssc
« Reply #5 on: June 07, 2010 - 08:36:21 PM »
It was the underhood lever.  Forgot to zip-tie it down...
Thanks!!!
« Reply #6 on: June 07, 2010 - 09:01:08 PM »
Thanks!!!
 :2thumbs: Drove me nuts too till I figured it out!
