Author Topic: After Rebuild Question  (Read 2174 times)
Offline mojavered
  • Someday!
Re: After Rebuild Question
« Reply #15 on: August 12, 2010 - 12:33:01 AM »
I just wanted to say thanks Terry!  I have all 3 gears and kick down works great.  Thanks for the help!
Jason
« Reply #16 on: August 12, 2010 - 09:48:22 AM »
What was the final solution?
Offline mojavered
  • Someday!
« Reply #17 on: August 12, 2010 - 10:57:11 AM »
It turned out that the shifter mech was hooked up correctly, just had to find the correct "place" for the shifter rod to be tightened down.  Then, I had to let some out on the kick down cable, which meant I needed to cut some of the housing away to give me the extra slack to allow it to shift at a lower speed.   Now if I can get some of the other bugs worked out!
Jason
