Author Topic: Cam install question  (Read 1109 times)
Offline shatar4
  • 71 Challenger
« on: June 06, 2010 - 07:51:20 AM »
After searching this site several times,I am more confused then ever. When putting the timing gear set on, does the marks go 6 and 12 or 12 and 12? Also, does #1 have to be at TDC while setting the marks or is that while installing the dist?
1971 Triple black 340 Challenger
Offline Changin Gears
Re: Cam install question
« Reply #1 on: June 06, 2010 - 08:15:37 AM »
The crank gear needs to be at 12.  The cam gear can be at either 12 or 6.  The reason is the cam turns at 1/2 crank speed, so if you turn the crank 1 revolution the cam will turn 1/2 revolution.
Offline shatar4
  • 71 Challenger
« Reply #2 on: June 06, 2010 - 08:18:24 AM »
So if I install it at 12 or 6 it wouldn't matter but when I install the dist. the #1 piston must be at TDC to be correct for timing?
Offline cwestra
« Reply #3 on: June 06, 2010 - 08:59:33 AM »
Yes, install the gear with #1 piston at top.  There is valve timing and ignition timing.  You are setting valve timing here.  Ignition timing is set when you install the distributor.
Corey - in Northern Indiana
Offline Aussie Challenger
« Reply #4 on: June 06, 2010 - 09:12:38 AM »
Set the crank at 12 & the cam at 6 o'clock, there is less likely of you getting the cam 1 tooth out that way.   :2thumbs:
Offline 72cudamaan
« Reply #5 on: June 06, 2010 - 09:26:06 AM »
If I cant fix it, it's broke
Andy  (phukker whither)
Offline Strawdawg
    • Vortex Buicks
« Reply #6 on: June 06, 2010 - 09:27:04 AM »
X2....when crank is at 12 and the cam gear at 6, this will automatically be Top Dead Center for number one.
Offline shatar4
  • 71 Challenger
« Reply #7 on: June 06, 2010 - 10:22:25 AM »
Thanks! That help clear it up for me. :cheers:
« Reply #8 on: June 06, 2010 - 01:06:26 PM »
with the cam @ 6 & the crank @ 12 you will be on firing stroke for # 6 cylinder
Offline shatar4
  • 71 Challenger
« Reply #9 on: June 06, 2010 - 02:07:30 PM »
Ok, confusion again. So if the crank is at 12 and the cam is at 6, it's firing on #6. So why have the dots line up at 6 and 12?
« Reply #10 on: June 06, 2010 - 02:28:34 PM »
I never said anything just go back to what you are doing !
#1&6 piston are oth at TDC at the same time , one is on exhaust stroke & 1 is firing , remember the cam turns at 1/2 the speed of the crankshaft so with the cam gear @6 oclock #6 is firing with the cam gear @ 12oclock #1 is firing
Offline shatar4
  • 71 Challenger
« Reply #11 on: June 06, 2010 - 02:31:59 PM »
So if I install the cam at 6 and the crank at 12, turn half way and I should be at TDC with #1 and then I can install the distributor.
Offline cwestra
« Reply #12 on: June 06, 2010 - 02:51:15 PM »
When I did mine, as a check I rotated the assembly while watching when the intake and exhaust cam lobes would lift the push rods on #1.
« Reply #13 on: June 06, 2010 - 04:00:56 PM »
Yes 1 full turn of the crank will line you up with TDC #1 firing
« Reply #14 on: June 07, 2010 - 08:51:33 AM »
As a precaution you should rotate the crank 2 full turns clockwise and re check to make sure the dots line up, don't turn the motor anti clockwise when doing the timing checks.
