Author Topic: Sure-grip Identification  (Read 784 times)
Offline boxfox
« on: June 06, 2010 - 12:01:43 PM »
If the differential is a sure-grip will it always have a "S" on the side or was that just a 1965 thing?
My particular application I am wondering about is a 8 3/4-3.23-2881489, from a potential seller
Re: Sure-grip Identification
« Reply #1 on: June 06, 2010 - 12:59:52 PM »
you can see the springs or clutches inside a sure grip case
Offline boxfox
« Reply #2 on: June 06, 2010 - 05:48:10 PM »
So will there be an "S" on the side to identify it?
« Reply #3 on: June 07, 2010 - 04:05:53 AM »
I have never seen an S stampd on a sure grip & have no clue what you are reffering to
Offline tactransman
« Reply #4 on: June 07, 2010 - 09:35:05 AM »
You have to remove the "pumpkin" from the rearend housing before you can verify what you have.
Terry-tactransman
Union, Mo.
Offline boxfox
« Reply #5 on: June 07, 2010 - 11:05:43 AM »
Alright maybe I read what I was reading wrong about them..
« Reply #6 on: June 07, 2010 - 02:42:26 PM »
The different ratios and sure grip combinations were identified using paint marks on the bottom of the center section.  There were no stampings on it that would tell you what was inside.
Offline Aussie Challenger
« Reply #7 on: June 15, 2010 - 07:26:29 AM »
If the axles are still in the rear turn the pinion flange around and both axles should turn in the same direction if it is a sure-grip, or have somebody try to hold one axle still, it won't if a sure-grip. If it is an open then the axles will turn in opposite directions.   :2thumbs:
