BS23JOB classifies it as an aar car. If it does have a vin tag on the dash, and the radiator core support should/ would have those same numbers as the dash vin also the cowel under the hood has the same numbers. Then getting a title isn't a big issue as some think You got a build sheet to, so that is a big plus on seeing the options. But the dash vin needs to match that build sheet, the radiator core, and the cowel, even the door should/could have the numbers. Don't give up, just cause no title if those other numbers come into play, then you can get a title easy enough, or a dmv vin and title.
