Author Topic: Distance between top of piston and spark plug  (Read 1212 times)
Offline 7Dcuda
« on: June 07, 2010 - 01:39:30 PM »
On a 440 with stock heads, how much distance is there between the top of the piston and the spark plug when the piston is at TDC?  I want to try the Champion RJ12YC plugs that this forum recommends but it is much longer than the Bosch plug that is currently installed....it's like twice the length.
Re: Distance between top of piston and spark plug
« Reply #1 on: June 07, 2010 - 04:14:20 PM »
That is the factory plug , you will have no clearance issues
Offline swede-cuda
« Reply #2 on: June 08, 2010 - 06:18:06 PM »
 :wave:wow,i bet your motor will feel better with the spark in the combustion chambers. :woohoo:
