Author Topic: does size really matter?  (Read 1424 times)
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« on: June 08, 2010 - 05:30:43 AM »
With an oil filter that is...
Looking at the stats below it seems that the only significant difference between both filters is the "maximum burst pressure".  Height should be no big deal if the space allows it.  So would a stubbier HEMI filter cause any harm if used on a 340 engine?
Fits 5.7 HEMI
Brand      Wix Filters
Manufacturer's Part Number      495-51085
Part Type      Oil Filters
Product Line      WIX Filters Oil Filters
Summit Racing Part Number      WIX-51085
Oil Filter Style      Canister
Height (in)      3.790 in.
Outside Diameter (in)      3.660 in.
Filter Bypass Relief Valve      Yes
Relief Valve Open (psi)      8-11 psi
Anti-Drainback Valve      Yes
Smallest Particle Filtered      21 microns
Maximum Burst Pressure (psi)      340 psi
Thread Size      3/4-16 in.
Gasket Outside Diameter (in)      2.834 in.
Gasket Inside Diameter (in)      2.462 in.
Gasket Thickness (in)      0.200 in.
Quantity      Sold individually.
Fits 340 CU IN
Brand      Wix Filters
Manufacturer's Part Number      495-51068
Summit Racing Part Number      WIX-51068
Height (in)      4.338 in.
Maximum Burst Pressure (psi)      275 psi
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline Supercuda
Re: does size really matter?
« Reply #1 on: June 08, 2010 - 08:30:26 AM »
Basically, the difference between the two is filtration capacity. Higher burst pressure is a good thing when you use a high-volume or high-pressure oil pump. It's insurance. More filter equals more filtration medium, and better protection for the engine. The little filter from the 2.2 fits the same filter boss as the big filter.
Offline Aussie Challenger
« Reply #2 on: June 09, 2010 - 08:21:00 AM »
Manufacturers use smaller filters because there is less oil to fill the filter therefore oil pressure more quickly.   :bigsmile:
Offline pink panther
« Reply #3 on: June 09, 2010 - 01:40:21 PM »
I get the mopar filter from the dealership to use on my 340
Offline Aracer
« Reply #4 on: July 18, 2010 - 01:12:59 AM »
The Moroso racing filter has good specs, for HV and HP pumps.#22470
