Author Topic: Re: emblem placement on '70 Challenger R/T  (Read 790 times)
Offline cudasam
« on: June 10, 2010 - 12:53:40 AM »
I have a 73 with a new hood ( no holes yet ) and I want to mount a set of NOS 340 four barrel emblems in the original locations on the side of the scoops. I have the dimensions for the hole locations, but I don't know what size the stock holes are . Also, the new emblems have a plastic sleeve on the mounting pins. Are these what hold them on, or is there speednuts on them ? Thanks, Mike    Hi Chryco, the car is getting better all the time.
« Reply #1 on: June 10, 2010 - 10:10:55 AM »
Glad youare enjoying it Mike  :2thumbs:
Re: Re: emblem placement on '70 Challenger R/T
« Reply #2 on: June 10, 2010 - 11:04:13 AM »
Plastic sleeves are not originally what were used..Barrel Nuts were they push in the hole then the emblem pin spreads them out creating  friction to hold. I found some at my local Ace Hardware
Offline HemiOrange70
« Reply #3 on: June 10, 2010 - 11:12:11 AM »
Match a drill bit with the emblem pin
Offline cudasam
« Reply #4 on: June 10, 2010 - 11:33:38 PM »
  Thanks for the info. I'll get some barrel nuts. I guess the hole has to be bigger to accommodate them !
