Author Topic: Need source on fuse pane:Hot when ignition is in start position, but not..  (Read 777 times)
Offline DocMel
What source on the fuse panel is:
HOT when the ignition switch is in the START position, but NOT hot when in the run position?
No fuse. Either the ignition switch  Run 1 run2  or it may be a dual ballast with one side burnt out
Offline TRIPLE-GREEN
    • Coupe Custom Accessories
Yeah, I  :iagree: I don't know what dodge thought this was such a great idea. But he is right. I had the same issue once.  :2thumbs:
Offline 422STROKER
  • Member Since 6/3/06
What are you trying to accomplish?
You could use the "start"ckt to trigger a relay while the key is in the "start" position only, if you so choose.  Relays cost about 5 bucks at the local parts store.
Tom
Tom
brown wire on the ign switch , it terminates at the coil side of the ballast
