Author Topic: This is bad right?  (Read 1620 times)
Offline 06Daytona
This is bad right?
« on: June 11, 2010 - 04:54:35 PM »
While I was playing around with my distributor I decided to check all the wiring from back when the electronic ignition was installed. The 'turn 5 wires into one' connections were in pretty bad shape so I cleaned them up and it seems to have helped a little more. I noticed what looked like water running down from the back of my voltage regulator so I decided to pull it off and take a quick look.
I think I'll be replacing it too.
1972 Cuda 340 4 barrel 4 speed that looks like a 71
2006 Dodge Charger R/T Daytona
2005 Dodge Ram 2500 Diesel 4X4
2006 Chrysler PT Cruiser Convertible (Kidmobile)
1972 Dodge Charger 318 auto
1970 Challenger 440/727 auto
1973 Plymouth Duster 340/auto (Making it Panther Pink for the wife)
2006 Honda Civic Hybrid (It doesn't save gas, it just diverts it to the Cuda/Challenger)
In desperate need of more property for my growing Mopar family
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
Re: This is bad right?
« Reply #1 on: June 11, 2010 - 05:03:48 PM »
yes replace it,,
72rtchallenger
what happens in the garage
stays in the garage
Offline 06Daytona
« Reply #2 on: June 11, 2010 - 05:09:01 PM »
It's even one of the few parts that Auto Zone has in stock in my city. They don't carry a lot of my stuff in stock so I'm changing the stuff that's in stock before I start special ordering bits.
Offline the_engineers
« Reply #3 on: June 11, 2010 - 05:10:55 PM »
Grab an extra...they go out more often than you might think.  Get a spare voltage regulator, too.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline 06Daytona
« Reply #4 on: June 11, 2010 - 06:55:44 PM »
They only had one in store, but they said they'd get another one soon. Now I just have to check and fix loads of wires around the engine. I think the black paint they used on everything is slowly eating the insulation on all the wiring. There seems to be a few cracks appearing on some of it and a few of them have  broken at the connectors
« Reply #5 on: June 11, 2010 - 07:26:45 PM »
Thats your voltage regulator. If the wires going to it , it will keep it from charging the battery
  • 72 to 70 clone
    • cardomain
« Reply #6 on: June 12, 2010 - 09:43:00 AM »
your engine wires are probably cracking due to the heat of being close to the engine,and age,,safe bet is to get a new engine harness,if you cant afford that ,,just make sure u solder your splices  and connections and make sure of good connections at the bulkhead plug
72rtchallenger
stays in the garage
