Author Topic: Pilot Bushing or Bearing?  (Read 1116 times)
Offline AMXguy
« on: June 11, 2010 - 11:49:36 PM »
Does anyone know of place that sells real bronze pilot bushings? I've tried 4 now and they are all 99% steel.  I'm a little unsure about the pilot bearing upgrade on my unmodified 440 and 833 stock input shaft it just seems too easy.
 What's the best option?
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Re: Pilot Bushing or Bearing?
« Reply #1 on: June 12, 2010 - 12:07:30 AM »
Did you try Mopar for the bushing ?
I am sure the part store one would be fine as well
Offline AMXguy
« Reply #2 on: June 12, 2010 - 12:20:40 AM »
No I haven't tried mopar, but all the others were like steel pipe a magnet wouldn't let go. I'm told to stay away from any pilot a magnet wants to latch on good to, I'm not sure.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline Changin Gears
« Reply #3 on: June 12, 2010 - 07:27:14 AM »
I haven't used a bushing in 10 years, the bearings work great.
Offline AMXguy
« Reply #4 on: June 12, 2010 - 10:01:12 AM »
So you just leave the bushing out and put the bearing in the hole where the converter would go? no modifications needed?  seems nothing is ever that easy.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #5 on: June 12, 2010 - 10:29:53 AM »
That's it, just make sure you put the seal side out.
Offline AMXguy
« Reply #6 on: June 12, 2010 - 01:05:24 PM »
The ones I find local are all needle bearings, I thought they should be a roller? the nearest Dodge dealer is 150 miles away so maybe I'll have to order one.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #7 on: June 12, 2010 - 03:59:48 PM »
Needle bearings is what it is...roller bearing. That is what they are talking about.  I put a roller (needle) bearing in my last engine that was in my Barracuda, this time I went with the bushing. The roller is a simple install tho. I just had 4 bushing in my tool box. I installed one in Sleepychallengers car, one in my new engine and have a couple left.
Dorman #   690-005    .753 x.940 x .880  clutch pilot bushing  Thats what it says on the box
Offline vinb
« Reply #8 on: June 12, 2010 - 10:26:21 PM »
Bearing,  Mopar part # 53009180AB
$20.00....
Offline swede-cuda
« Reply #9 on: June 16, 2010 - 03:37:51 PM »
:wave:im not sure but you might have to cut of your input shaft? a bit ,to make it work with a bearing.
« Reply #10 on: June 16, 2010 - 06:28:50 PM »
No mods required
« Reply #11 on: June 17, 2010 - 12:05:54 AM »
