Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
74 Barracuda Gauge Problem
« previous
next »
Print
Pages: [
1
Author
Topic: 74 Barracuda Gauge Problem (Read 1037 times)
CUDAMAN1970
Jr. Member
on:
June 12, 2010 - 11:49:51 PM »
Started my 74 Barracuda with Ralley Gauges for the 1st time today. Car starts up and runs fine but alternator gauge flickers and all other gauges do not function. My mechanic neighbor is helping me with the project and he tried to ground the temperature and oil pressure gauges and the effort had no effect on the gauges. Removed "black" wire from connector and alternator gauge no longer flickers but other gauges do not work.
Head lights and fog lights work - car starts right up and all fuses are good.
Any ideas? What could be causing the problem?
Thanks!
Logged
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Re: 74 Barracuda Gauge Problem
Reply #1 on:
June 12, 2010 - 11:57:59 PM »
Sounds like you may have a bad instrument voltage regulator.. Grounding wire from sending unit is a good method to test gauges but they need + power to.
http://www.allpar.com/history/mopar/electrical2.html
Replacement solid state available
http://rt-eng.com/mediawiki/index.php/RTE_limiter
Last Edit: June 13, 2010 - 12:01:02 AM by Bullitt-
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
CUDAMAN1970
Jr. Member
Reply #2 on:
June 13, 2010 - 10:45:20 PM »
We did some more testing today and found that if we took power away from the fuel gauge, the oil pressure, alternator, and temperature gauges work. We tested with a different voltage regulator from another cluster and got the same results with either. Looks like we are going to have to pull the cluster.
Anyone haver any suggestions . . . .
Logged
72rtchallenger
Sr. Member
72 to 70 clone
Reply #3 on:
June 13, 2010 - 10:49:03 PM »
did the fuel gauge work before it was unhooked
Logged
72rtchallenger
my challengers restro at
http://www.cardomain.com/ride/399010
what happens in the garage
stays in the garage
CUDAMAN1970
Jr. Member
Reply #4 on:
June 13, 2010 - 10:54:50 PM »
Fuel gauge did not work before or after.
Logged
72rtchallenger
Sr. Member
72 to 70 clone
Reply #5 on:
June 13, 2010 - 10:58:53 PM »
maybe the sending unit in the tank is bad maybe shorted out,, or the wire to the tank is shorted out,,use a muti meter and see if its shorted out to the frame somewhere
Logged
72rtchallenger
stays in the garage
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
