Author Topic: Rear end sagging???  (Read 3971 times)
Offline mjb765
Rear end sagging???
« on: June 13, 2010 - 04:34:10 PM »
I have a 71 chally r/t and I think the rear end is a bit low. I know the previous owner lowered the torsion bars in front, but the rear also looks low. Cranking up the front is one thing on my to do list, but the rear would need new leafs. Could someone give me a height measurement fron the ground to the center of the rear wheelwell so I could compare it. The car has 275/60 R15 tires and the wheel well is 24" fron the ground. Any help would be appreciated....
Offline mjb765
Re: Rear end sagging???
« Reply #1 on: June 13, 2010 - 06:40:59 PM »
Mine was trunk empty, tank almost full. May be time for some new springs.....
Found these while looking around today. What do you think?
http://www.firmfeel.com/leafspri_e.htm
Offline mjb765
« Reply #2 on: June 14, 2010 - 11:25:52 AM »
Does anybody have any suggestions on where to get a good set of rear leafs??
« Reply #3 on: June 14, 2010 - 11:37:09 AM »
I bought mine from Espo. They can even sell you springs with a 1" or 2" over stock height lift if you really want to raise it up.
  http://www.springsnthings.com/
Offline FJ5_440
  • Wisconsin
« Reply #4 on: June 14, 2010 - 11:40:06 AM »
Quite a few of us have used Espo springs and things.  They will make a pair for you in stock height or raise or lower the car.  I personally find their +1 inch spring to be just right for the basically stock look without the slightly "saggy bottom" look the stock springs had.  They are made of quality materials and won't "go flat" after a couple years.  do a search for Espo, or spring height and you will get tons of info with comparison pics.
I would just call them to find pricing, but this is their website.
** Shane **
Offline mjb765
« Reply #5 on: June 14, 2010 - 11:42:04 AM »
Are the pics in your signature stock height or raised in the rear??
« Reply #6 on: June 14, 2010 - 11:50:42 AM »
I definitely raised it up. I wanted to see the whole tire back there.
Offline mjb765
« Reply #7 on: June 14, 2010 - 11:56:27 AM »
Is that 1" or closer to 2"
The center of my wheelwell is 24" from the ground. I am trying to find what stock would be so I can order +1 or +2 for the springs.
« Last Edit: June 14, 2010 - 11:59:49 AM by mjb765 »
« Reply #8 on: June 14, 2010 - 02:32:09 PM »
Please remember that Chrysler never specified a rear ride height on the E bodies, so actual measurments can be all over the board. In their installed position, the stock leaf springs should vary from almost flat, to only 2" of arch. So unless your having problems with wheel bounce, spring wrap up, or bottoming out, your springs may be exactly where they should be.
Offline mjb765
« Reply #9 on: June 14, 2010 - 03:01:48 PM »
I tried to upload pic to show you what I was talking about and I got an error. I just PM'd a moderator. Hopefully I can upload it later today.
Offline swede-cuda
« Reply #10 on: June 14, 2010 - 03:13:46 PM »
 :jumping:my -70 cuda 383 .original untouched springs and 255/60/15 bfg tires are 26" from ground to fender arch.the distance is 26" on the front to.ive driven the car with 5 fullgrown guys(including me)with no problems. :woo:
Offline mjb765
« Reply #11 on: June 14, 2010 - 03:29:33 PM »
Thanks for the measurement....that answers my question
« Reply #12 on: June 14, 2010 - 03:37:54 PM »
I think you might want to go with a 1" lift on your springs. Here I measured 14" from center to the wheel lip for reference.
Offline mjb765
« Reply #13 on: June 14, 2010 - 03:43:19 PM »
I just measured--11 3/4" from the center of the center cap to the wheel well. Did you go with +1" or +2" to get that?
« Last Edit: June 14, 2010 - 05:20:30 PM by mjb765 »
« Reply #14 on: June 14, 2010 - 06:31:51 PM »
I went 2" over, but I am hesitant to recommend going that far if you don't want to see the entire tire like I do. I don't know what your taste is. I have 15" wheels 255/60 series, so your tires will be taller than mine. Something to think about...
 You can see in my first pic that there is a gap between the tire and wheel well lip.
