Author Topic: Chally headlight bucket adjuster and tension spring  (Read 1079 times)
Offline femtnmax
« on: June 13, 2010 - 04:58:30 PM »
For 1970 chally, bought new headlight adjusters, and have old bucket tension springs.  The problem is the tension springs seem too short.  Is the screw that holds the spring to the headlight backer structure supposed to tighten the spring all the way to the backer structure, or is there exposed screw length?
Hope I've made the question clear...or is it mud??
Phil
Offline Brewster_440
Re: Chally headlight bucket adjuster and tension spring
« Reply #1 on: June 13, 2010 - 05:49:57 PM »
From what i know the screw holds the tension spring tight to the headlight bucket. I have a 1970 with a fiberglass nose, and fiberglass headlight buckets, and that is how mine is set up. keep in mind, mine is not a stock set-up, but a mock-up of stock in fiberglass. make sure you have the right adjusters, and the tension spring holds the headlight as it "rocks" around the opening in the headlight bucket to get your lights in adjustment. there will be tension on the adjuster spring. that is what holds the headlight lamp from flopping around. i can take some pics if you need me to.
1968 GTX 426 Hemi - gone
1967,65,72 Darts - gone
1970 Challenger - current project
First time behind the wheel of a car was in a 1973 Chrysler Town & Country w/440 on Daytona Beach
