Rear springs, - same on B and E..???
Author Topic: Rear springs, - same on B and E..???  (Read 905 times)
Offline cowboy
  • Denmark
    • CowboyCars.dk
« on: June 14, 2010 - 05:11:12 AM »
Is the rear springs the same on late 60'  B- and E-body..???
Re: Rear springs, - same on B and E..???
« Reply #1 on: June 14, 2010 - 08:42:35 AM »
No. The B body main leaf is an inch longer. On XHD versions, B body have extra leaves on the right side only. E bodies have extra leaves pointing forward on the right side and backwards on the left side.
However, is you retain the E body main leaf, you can swap over the rest of the B body pack.
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #2 on: June 14, 2010 - 09:59:41 AM »
OK, to be "bolt on", it has to be for E-body only..
P4452982 O.E. Leaf Spring — Right (1966–72 B-Body) 99.50
P4452983 O.E. Leaf Spring — Left (1966–72 B-Body) 99.50
P4452984 O.E. Leaf Spring — Right (1970–74 E-Body) 92.50
P4452985 O.E. Leaf Spring — Left (1970–74 E-Body) 92.50
B-Body: front 22", rear 36".
What is the rear on E-body..  35"..???
« Reply #3 on: June 14, 2010 - 02:29:22 PM »
Correct. They both have 22" front segmetns, but E bodies have a 35" rear segment.
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #4 on: June 14, 2010 - 02:34:12 PM »
What is the rear on A-body.???
Got a pair of those laying around.
« Reply #5 on: June 14, 2010 - 02:35:50 PM »
Rear on an A body spring is 35, but the front is only 20". So, you could use A body springs on an E body, but to do so you would now need super stock front hangers.
