Author Topic: 71 cuda fender turn signal indicator location  (Read 4342 times)
Offline culp71
« on: June 14, 2010 - 01:32:32 PM »
I got new fenders for my 71 cuda, but no holes for turn signal indicators can some post pics with measurements, like somedid for the penstar passenger location, very help ful as well.
Offline acudanut
Re: 71 cuda fender turn signal indicator location
« Reply #1 on: June 14, 2010 - 04:26:10 PM »
 LOOK at your old ones  :2cents:
Offline culp71
« Reply #2 on: June 15, 2010 - 11:10:16 AM »
i do not have the orginal fenders
Offline acudanut
« Reply #3 on: June 15, 2010 - 02:08:34 PM »
 Find a anothe car to look at or just go without. :2cents:
« Reply #4 on: June 15, 2010 - 02:35:15 PM »
Quote
 ::) :nono:
Sorry, I can't help you with the measurements you need but I'm sure someone will come through for you.  This is generally a good site and most people are glad to help when they can.
wagesofsin
« Reply #5 on: June 15, 2010 - 02:45:10 PM »
ill look at some of the ones at the shop. if they have the holes ill make you a template.
Offline Canadian Cuda
« Reply #6 on: June 15, 2010 - 03:03:17 PM »
if it's the same for 70 i have all the measurements written down
Geoff
70 Cuda 440-4, auto, 8 3/4 sure-grip
« Reply #7 on: June 15, 2010 - 05:18:01 PM »
I could give you the measurements for a Challenger, but I'm sure that won't help you.    :grinno:
wagesofsin
« Reply #8 on: June 15, 2010 - 05:20:46 PM »
no help here sorry, my later fenders ( 73) have em, but all my 70 - 71 dont. :sadwavey:
Offline dutch
« Reply #9 on: June 15, 2010 - 06:02:31 PM »
it is...
*** Bart ***
« Reply #10 on: June 15, 2010 - 06:05:07 PM »
here you go, sorry it's not a little bigger but it should suffice. also which you cant see in the pic is that there should be a small notch on the most rearward hole for the peg to fit.
« Last Edit: June 15, 2010 - 06:06:43 PM by Canadian Cuda »
Geoff
Offline culp71
« Reply #11 on: June 16, 2010 - 11:13:26 AM »
perfect thank you all!
Offline ragtopdodge
« Reply #12 on: December 01, 2010 - 11:02:37 AM »
Were those measurements taken using a rigid measuring tape/ruler?  Or using flexible, soft measuring tape (like used in sewing)?  If the latter, was the tape resting on the fender?
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
« Reply #13 on: December 14, 2010 - 03:34:44 PM »
i did it while ago but im pretty sure it was a rigid ruler
Geoff
Offline moparclown
« Reply #14 on: December 19, 2010 - 08:25:05 PM »
here ya go
