front suspension
Author Topic: front suspension  (Read 1649 times)
Offline Lovemy440
  • mopar or no car
front suspension
« on: October 18, 2004 - 10:52:41 PM »
ok I have been looking around a little more and found another place.
http://www.autoweldchassis.com/frames.ivnu
on their front suspension kit you use mustang ll spindles
does this mean i have to buy mustang front disk brakes?
That means the lug pattern will be diiff. form the rear?
can someone talk me through this
Nos is neat,
Injection hard to beat
But when it"s time to get goin
I'd rather be blown
Re: front suspension
« Reply #1 on: October 18, 2004 - 11:07:58 PM »
is this car street driven ???
mustang II stuff works for racing  fairly light for street use , You can get 10" rotors with 5 hole Mopar bolt pattern , stock mustang is 4 bolt
For street use I would use the firm feel quick ratio box , to go to pinion there has not been a goood system developed yet  most do not have correct ackerman to work with the steering in front also no good spindle has been built for front steer most eliminate the T bars which thee frame is not built to take , what I would like to see is a tubular K frame that uses the T bars & stock lower control arms  with a properly made spindle for front steer & using tubular uppers
 I guess I have to build it myself
Offline Lovemy440
  • mopar or no car
« Reply #2 on: October 19, 2004 - 07:26:37 AM »
ITS A PRO STREET WITH A 540 CI ENGINE.
IT WILL PROB. BE  80 OR 90% STRIP AND 10 TO 20 % STREET
WITH THAT KIT WHAT KIND OF STEERING CAN I USE?
ANY OTHER OPINIONS
Nos is neat,
I'd rather be blown
« Reply #3 on: October 19, 2004 - 11:57:30 AM »
that kit requires changing the fron tsib frame out to use the componenents , are you looking at doing that or do you just want a bolt in replacment light K frame ?
Offline Lovemy440
  • mopar or no car
« Reply #4 on: October 19, 2004 - 05:07:38 PM »
a little of both I want lighter but not a 3,500 kit by magnumforce
Nos is neat,
I'd rather be blown
Plum6Pak
« Reply #5 on: October 19, 2004 - 11:26:30 PM »
Hey LM440, check out the pictures that OneBadHemi has on the e-body pictures, he has a 70 Challenger with the Alterkation front end in it, you should get with him and check it out!
Here is a picture of the Alterkation, you probably already have seen this but here it is again, along with the good ole reliable!
[attachment deleted by admin]
Offline gichy
« Reply #6 on: October 26, 2004 - 03:51:15 PM »
That's beautiful !!!!!!!!!
1974 Barracuda, 340cid, 4 speed OD !!
Plum6Pak
« Reply #7 on: October 26, 2004 - 05:34:37 PM »
Hey Gichy, I don't know which one you are talking about but the original K frame setup is mine after I got it finished. It was a bugger to cut out on photosuite, you can still see smudges and not a very clean job on the cut out. Anyway, thanks either way!  ;D
