Author Topic: How much power can you get out of a Big Block for $10,000?  (Read 771 times)
Offline lemming303
  • San Antonio, TX
« on: June 15, 2010 - 11:18:16 PM »
Just curious. Since my car is a long ways out I like to "window shop" and look at parts and stuff, even though I still have no idea what I'm gonna end up buying. So, on average, what kind of a Big Block build could you come up with for 10,000?
Kevin
73 Challenger Rallye - first project
Offline moper
Re: How much power can you get out of a Big Block for $10,000?
« Reply #1 on: June 16, 2010 - 12:14:53 PM »
If you have a block and headers and are using a single 4bbl you should be able to make a reliable real 550-600hp in varying displacements. This assumes pump gas, street/strip use, buying everything else new, and no dyno time.
« Reply #2 on: June 17, 2010 - 12:08:29 AM »
You can get a ot of power for that even over 600 hp & 700 tq depending what you use , but using a stock block build with stroker pkg & girdle & a good set of heads & cam it is easy to make power
Offline lemming303
  • San Antonio, TX
« Reply #3 on: June 21, 2010 - 12:51:06 PM »
That's good. The biggest reason I was gonna stay with the 340 is that the weight is less. But now I am kind of leaning toward the BB. But then again what I want changes all the time, as I am so far off from being done. I'm gonna go look at a 318 today so that I will have a motor once I get the floor pan welded in and start on the firewall. So I will have a motor to run while I build a good one.
Kevin
Offline djwhog
« Reply #4 on: June 22, 2010 - 09:19:56 AM »
for 7k range a stroker 340 =416 should get you 500-550 hp on pump gas .
Key to all of these engines is a strong lower end 1st, 2nd good head work for much better than stock flow, 3rd improve oil system too and or invest the $$s if you are going to 10k in some performace heads and have them ported and runner intake matched too.
A stroker 440 can easy make 750 HP with good heads and a enough torque to break the drive train too.
If you put alum heads, intake, and water pump housing the weight will be near that of a SB too.
Offline go-fish
« Reply #5 on: June 22, 2010 - 09:54:40 AM »
You can make enough to twist the body with 10K. The real question is, what do you want to do with it? Cruiser? Racer? I know, a little bit of everything, right? I would say start off with a 400 engine block and a stroker kit based on forged rotating assembly, girdle, aluminum CLOSED chamber heads, and an M1, Mopar part# P4529462.
Look over at Moparts for good deals on unwanted intakes and cylinder heads.
