Author Topic: shifter rod clearance  (Read 749 times)
Offline 30below
« on: June 16, 2010 - 08:56:41 AM »
Anybody else have trouble with the rods rubbing the trans xmember?When i took the car apart,there was some shims between the trans and the mount.Wasnt sure what they were for,so didnt reinstall them.After putting the rods in,the 1-2 and 3-4 rub slightly on the xmember.Guess i found out why they were there.Is this normal to maybe have to shim?Its maybe a quarter inch.
Offline Supercuda
Re: shifter rod clearance
« Reply #1 on: June 16, 2010 - 09:34:55 AM »
Welcome to production tolerance stackup. Shimming will solve the issue, but the trans mount may also be compressing some. Are you using rubber or polyurethane?
Offline 30below
« Reply #2 on: June 17, 2010 - 08:27:11 AM »
Its rubber.And probebly the original.
Offline Supercuda
« Reply #3 on: June 17, 2010 - 09:14:05 AM »
You are suffering from a sagging mount, and probably tolerance stackup, as well. Change the mount, and consider urethane.
