Author Topic: Middle please?  (Read 1586 times)
Offline erat340
Middle please?
« on: June 16, 2010 - 12:39:20 PM »
Hey you audio gurus, anyone know how to get MIDrange sound? Ive got an Eclipse head, four channel out, feeding a Fosgate punch amp in the trunk, 6x9 5way in rear, and 6 inch JVC in doors. Gobs of highs, tons of bass, just missing the depth.
Re: Middle please?
« Reply #1 on: June 16, 2010 - 03:49:08 PM »
Part of the problem is all the power is in the rear. Fade to the front & adjust base & treble for best tone then fade to rear where you get just enough base.  You may find that the volume is to low if so add an amp for the front.
  I'm using an old school (read cheap) graphic equalizer, can definitely contour the sounds with this, but everything has to be run through an amp.
