Author Topic: Electric Pump-Filter before the pump  (Read 1148 times)
Offline Strawdawg
    • Vortex Buicks
« on: June 16, 2010 - 03:08:15 PM »
As we are on the topic of electric pumps, how many of you are using a filter before the pump other than the sock on the pick up in the tank?
 I ask because the Holley on my current project died (Thank God!) and I am getting ready to install a new pump.  The Holley did not seem to have any trash in the pump and the old pick up sock does not look bad either even tho I am going to install a new pick up while I am messing with this end of it.
I do have a large cartridge type filter that I can use...just trying to save some effort on fabbing brackets to hang stuff down to the bottom of the tank... :)
Offline ireland383
Re: Electric Pump-Filter before the pump
« Reply #1 on: June 16, 2010 - 03:28:45 PM »
I'm using a Napa metal one before the pump nothing fancy.
1971 Plymouth Barracuda
« Reply #2 on: June 17, 2010 - 12:09:56 AM »
if you have the stock sock filter on the pick up tube I would not use another filter before the pump
Offline moper
« Reply #3 on: June 17, 2010 - 07:12:25 AM »
I'm more concerned about trash fromt he pump getting to the carb, so I use the largest filter I can fit (usually the Fram HPG-1 canister-type) just after the pump. The sock will give the pump more than enough protection.
Offline ireland383
« Reply #4 on: June 17, 2010 - 07:55:01 AM »
Per instructions for my pump it said to use the filter before the pump.   :dunno:
Offline 71Plym
  • 1971 B2 Cuda
« Reply #5 on: June 17, 2010 - 08:35:55 AM »
I have a 100 micron filter before the pump and 10 micron filter after the pump as per Aeromotive.
Offline Strawdawg
    • Vortex Buicks
« Reply #6 on: June 17, 2010 - 11:11:01 AM »
This is what I had in mind to do...particularly since I had already rigged the cannister where I could use it after the pump when the Holley was working...
Offline Strawdawg
    • Vortex Buicks
« Reply #7 on: June 17, 2010 - 06:27:18 PM »
one I have is rated at 125 gph....should work for my current needs
