Author Topic: 4.7 dodge motor in a challenger? help>?>?  (Read 543 times)
Offline 4THECHALLENGE
« on: June 16, 2010 - 03:42:43 PM »
how hard is that to do?
 is the same work involved for a 5.7
im looking for aan affordable motor with fuel injection and i found a few but will they fit? someone told me truck motors are taller...
so will it clear?
how much cost am i looking?
will my 949 tranny work?
what will i need?
anything else i should look for?
is this even a good motor?
thanks all  :hyper:
Offline Cooter
    • christinecarclub.com
Re: 4.7 dodge motor in a challenger? help>?>?
« Reply #1 on: June 16, 2010 - 03:44:32 PM »
You are looking at alot of fab work..not to mention the Amount of Electrical work to get all that F.I. to work properly..I know the engine mounts are Way different...I believe the bellhousing is different as well..
Offline GreenFish
« Reply #2 on: June 23, 2010 - 08:42:55 AM »
Just a thought, if you all you want is EFI check out the FAST EZ EFI system.
http://www.summitracing.com/parts/CCA-30226-KIT
I dont use it but I want it. You can easily build a 360 or small block otherwise and throw on this efi system and have what you are looking for. I think the 4.7 would be a waste of time.
