Author Topic: 18x9.5 rims on a b-body rear,will they fit good if they are the mustang offset?  (Read 672 times)
Offline TROUBLE987
i have a B-body 83/4 under my cuda and im wanting to run the mustang size wheels on the rear and im worrying about having problems with them not fitting right,i got the dr diff relocation kit already installed and i was thinking maybe i might run into some problems..what you guys think?
Offline 73challenger_TN
I have not run that setup but I would think you would need a spacer for that setup. Because mustang wheels typically have more backspacing and your using a narrow rearend. I would think your tires would scrub or hit the springs. If you had a ebody rearend they might be OK.
Offline TROUBLE987
yeah thats what i was thinking..
