Author Topic: may be a dumb question  (Read 1777 times)
Offline 06Daytona
« on: June 17, 2010 - 05:26:01 PM »
Since I'm a little short on cash this week I decided to pull a few parts from the engine compartment to clean them up. I pulled the vapor canister and the washer fluid reservoir since the nasty flat black is on everything. I'm doing the outside of the reservoir with lacquer thinner and it's working pretty well although it takes a little scrubbing. Is there anything that will get the inside of the reservoir clean without scrubbing? Kinda fill reservoir and shake sort of thing
1972 Cuda 340 4 barrel 4 speed that looks like a 71
2006 Dodge Charger R/T Daytona
2005 Dodge Ram 2500 Diesel 4X4
2006 Chrysler PT Cruiser Convertible (Kidmobile)
1972 Dodge Charger 318 auto
1970 Challenger 440/727 auto
1973 Plymouth Duster 340/auto (Making it Panther Pink for the wife)
2006 Honda Civic Hybrid (It doesn't save gas, it just diverts it to the Cuda/Challenger)
In desperate need of more property for my growing Mopar family
Offline 06Daytona
Re: may be a dumb question
« Reply #1 on: June 17, 2010 - 05:38:22 PM »
Inside is just dirt and some discoloring. No paint that I can see in there
« Reply #2 on: June 17, 2010 - 11:09:50 PM »
You might try some bleach....1/3 bleach to 2/3 water & let it soak a few hours....your lucky if the OE plastic has held up, while most of my car held up well in dry storage the reservoir fell apart.
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #3 on: June 18, 2010 - 04:42:02 AM »
Scrubbing bubbles cleaner works miracles on soap scum and dirt in the shower and bath tub.  I don't see why it wouldn't work for your washer reservoir as well.  I'd give it a try if the bleach soaking doesn't work.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
« Reply #4 on: June 18, 2010 - 09:07:13 AM »
Completely forgot what your dealing with...If it's yellow/orange inside it's rust, try CLR straight.
Offline 06Daytona
« Reply #5 on: June 18, 2010 - 09:49:49 AM »
I let it soak with the bleach/water combo for a couple of hours and it cleaned it up quite a bit. I'll get CLR and try that to finish the cleaning. It's really just yellowing now, so I'll give scrubbin bubbles a try too. I did find a small crack, but it's in the bottom where I can epoxy it without it being visible. If it comes out really well I'll post pics along with what I did. If it looks clean, but nothing special I won't bother.
Offline Aussie Challenger
« Reply #6 on: June 19, 2010 - 12:37:30 AM »
I just throw a hand full of small stones about 1/4" with a little water and shake, everything comes out clean, don't forget to rinse afterwards.   :2thumbs:
